Old 06-15-2019, 08:07 PM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Cool
Originally Posted by cycleguy55 View Post
Has anybody ever put these on a flow bench to evaluate how restrictive they really are - or aren't?
Edit: I just found this, posted to https://www.ffcars.com/forums/17-fac...r-cleaner.html by 'mrmustang'. Hmmm....
Back to the original question, and dating back over 18 years
427 center oiler, 10:2:1 compression, 650 holley DB (already dyno tuned) fairly mild street cam as a base for the test on a "chassis" (not engine) dyno. This was done as we were baselining a new chassis dyno at a friends shop and thought it would be interesting to be able to show his customers the difference of what something as simple as an air cleaner could make.
My notes are as follows:
no air cleaner: 322hp
then 14X2 "K&N" air cleaner: 314hp
then 14X4 "green" air cleaner with drop base:324hp
then Stelling and Heller air cleaner (stock filters as we did not have K&N or Green filters in stock at the time):302hp
All of the above were done one after the other. No tweaks or changes where done to the carb or engine timing. Strictly a demonstration for about 20 customers who were at the shop that Saturday. All HP above was measured at the rear wheels.
The car was ERA321, dark blue metallic, running a toploader 4spd and 3:31 rear gear ratio.
Second Strike Air Cleaner Calculator: https://www.secondstrike.com/Technic...leanerCalc.asp
I can confirm those where actual results, less then a few minutes apart on a brand new Dynojet chassis dyno. Real world, real wheel HP data. Somewhere in my old files I may have the torque numbers to go along with this.
As a side note, the numbers above where done before we had a K&N or Green Filter-14" filter top. The filter top would had a huge amount of airflow vs the chrome lid that was used at the time of the chassis dyno runs.
Bill S.
