Old 06-19-2019, 07:39 PM
pormgb pormgb is offline
Banned
Cobra Make, Engine: Rowan Replicars, 352 4V
I have the same front suspension on my replica. You have a Ford Pinto cross member (can tell by the large holes) with upgraded tubular control arms (stock length?). When I received my project, I had front wheel rub problems, so I installed a set of 7/8" shorter upper control arms and redrilled the lower control mounts one inch back. Modified the steering rack and this tucks in the front wheels quite a bit. You can also get 1" shorter upper and lower control arms, very popular on Hot Rods that use Mustang 2 suspension and need to reduce the front track width. I'm and also using Mustang 2/Pinto QA1 adjustable coilovers that allow me to set rebound\compression and ride height.
Regarding the strut rods, I have thought about removing mine, but I need to verify how the tab (strut rod delete control arms) can be welded to the pinto cross member. Since my car has a very heavy original 352 4V, I am running 600lb front springs, and these springs are custom made to fit the Pinto upper spring housing. My car is pretty well balanced, and also has a Jaguar rear end with dual 250lb springs per side. It also looks like you have Carerra steel bodied single adjustable shocks, these only allow ride height and have fixed valving, and are also a common Pinto\Mustang 2 shock upgrade. One of the issues with a heavy FE motor is nose dive when braking, and this can be controlled with shocks that have adjustable valving and the correct spring rate.
I have these shocks, and you can order different spring rates with the kit.
https://www.speedwaymotors.com/QA1-M...SABEgJ8C_D_BwE
Rowan Replicars 1965 Cobra Replica
352 4V, T5, Jaguar Posi rear end with 3.30 gears.
https://www.facebook.com/pormgb/
