Old 01-06-2020, 06:02 PM
patrickt patrickt is offline
Originally Posted by AdamIsAdam View Post
I've driven two and looked at many others, and I have a few questions about driving the different versions:
Is this a pedal design (angle of pedal assembly) or perhaps is this car just unusually stiff? It's not hydraulic.
Generally speaking, the more you spend the more you'll get. SPF cars can be good, but you can also do better. Do yourself a favor and test out a really well sorted out ERA/KMS/CSX car and then benchmark everything else against it. And I didn't even know you could get a SPF with a non-hydraulic clutch, unless you were referring to a non-HTOB clutch. A properly set up master/slave/fork based clutch will be reasonably easy on your leg and hold your horsepower.
