Old 01-12-2020, 11:03 AM
AndrewB AndrewB is offline
Cobra Make, Engine: ERA 3012
Originally Posted by KevinW View Post
I've got a set of these:
https://vintagewheelsus.com/index.ph...roducts_id=761
Anyone fitted these? - think I understand how to pull off the old XJ rear hub.
I'm less clear about what is needed to fit the new hub, and whether I need to worry about measuring end float etc.
Hi Kevin,
Yes, you would need to check end float and shim as necessary when replacing the hubs.
ERA has a great doc on it - Setting the Hub Carrier axle bearings
Hope this helps!
