Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Old 01-12-2020, 09:07 AM
Default Fitting rear hubs (not adaptors) for knock-off wheels: XJ axle
I've got a set of these:
https://vintagewheelsus.com/index.ph...roducts_id=761
Anyone fitted these? - think I understand how to pull off the old XJ rear hub.
I'm less clear about what is needed to fit the new hub, and whether I need to worry about measuring end float etc.
Crendon 427, in the making
http://crendonreplicas.com/
Old 01-12-2020, 09:47 AM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
i have a brand new set of polished 17" wheels for those hobs for sale cheap!!
Old 01-12-2020, 10:03 AM
Cobra Make, Engine: ERA 3012
Hi Kevin,
Yes, you would need to check end float and shim as necessary when replacing the hubs.
ERA has a great doc on it - Setting the Hub Carrier axle bearings
Hope this helps!
