Old 01-17-2020, 09:44 AM
Lou1119 Lou1119 is offline
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
Originally Posted by FredG View Post
I will post updates and info as I get into it. Mounting bar came with it. Probably going to do a separate switch with a circuit breaker and relay. I want to test them with my DC power supply. Here is where I got them from.
https://www.parts123.com/parts123/yb...Z5Z5Z50000027b
I purchased the same set up and installed them on my SPF Cobra. The mounting brackets on the side are a joke. There is no way that you can use them. They are so flimsy that you can't weld them to the bar. You will have to fabricate something to be able to attach the bar to. Not impossible but it will be necessary. Mine is operated on a dedicated circuit with a relay controlled by its own switch on the dash board. I agree that the puller fans do a great job but the pushers are for eye candy.
