Old 06-11-2002, 07:45 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
RZ, There is a short jumper harness # 1002320. This can be wired to your dimmer switch. #141 is power, #143 is hi-beam, #145 is low beam. The hi-beam indicator light is a pushin style light that Classic uses. Wire # 144 and a ground goes to the light. It is normally a blue light to show you when the hi-beams are on.
The wiper wiring is determined by the type of switch you have. If it is a Lucas it is wired different. Let me know what type of switch and I will tell you how to wire it.
The dash lights all get power from #146 so you can wire them through a switch.
Wire #157 and #161 are for the fan override switch. Let me know how your fan is wired, what type it is, if you are using a thermostat and then I can tell you what to do with the wires.
All the wires that aren't used can be cut or taped.
Don
