Old 06-06-2020, 06:15 PM
Tjd Tjd is offline
Disconnect lower ujoint from the intermediate shaft that on the steering rack Pinion and see if it’s in the steering column or in the rack that’s causing the bind there should be next to zero restriction when you turn the steering column when it’s not connected to the rack give it a try and good luck
Tom
