Thread: Name this tick!
Old 06-14-2020, 09:26 AM
AdamIsAdam AdamIsAdam is offline
I tightened all header bolts up against the lock washers. With valve cover off, I cranked the engine and watched the rockers, everything looked ok.
I sprayed soapy water, then I fired it up. The water was gone in seconds. It's ticking away. My stethoscope doesn't tell much. The valves are quiet, fuel pump, water pump, distributor. All quiet. The sound seems to be coming from drivers side front, down low I think.
I took temp readings of exhaust and every cylinder was about the same.
It's possible it still has a header gasket leak, especially if it's from the bottom since I can't get my stethoscope under there. Otherwise, what can it be? Spun bearing? Yuk
Do header gasket leaks go away with increased RPM like mine does? It's been a long time since my last one.
Adam
Fulfilling my lifelong dream to own a Cobra... MISSION ACCOMPLISHED!
MKIV FFR 347 cid, Levy T5, 3.55 3-link.
SOLD Replaced by something with a Flat-6
