Old 06-24-2020, 04:16 AM
strictlypersonl strictlypersonl is offline
Originally Posted by cycleguy55 View Post
IMO,...
the best place for the sensor is in the bottom hose / return to the water pump and engine. That way you're measuring the return coolant temperature, and if vehicle movement provides enough airflow and cooling the fans won't come on. A second choice would be a probe that goes into radiator fins.
Once downside of the bottom hose location is you may need a different sensor / switch if the one you have isn't adjustable. You may want to switch on fans at a lower temperature if you're reading it from the water pump inlet temperature / lower hose.
ERA uses the bottom hose method. The thermo-switch is pretty low, at 75C, but the fan seldom comes on except when the car is stationary.
