Thread: Belt tension
Old 09-30-2020, 09:42 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Originally Posted by Gaz64 View Post
From Peterson Fluid Systems:
Tuesday Tech Tip:
Setting belt tension & HTD belts (radius tooth) vs. Gilmer belts (square tooth).
Unlike v-belts and serpentine style belts, toothed belts such as HTD and Gilmer's don't need to be overly tight. The teeth on the belt do the work, not the tension. The rule of thumb to check belt tension is you should be able to grab the belt in the center between the two pulleys and turn it 90 degrees so the teeth are facing you. If you can turn it 180 so the teeth are pointing straight up at you, its too loose. If you can't turn it 90 degrees, its too tight.
Over tightening belts can cause excessive belt walking and occasionally premature pulley wear.
I have looked all over and ask alot of people this question and you sir are the first to give a good answer .Thank you very much!
