Thread: Belt tension
Old 10-01-2020, 11:37 AM
cycleguy55's Avatar
Originally Posted by hauss View Post
Let"s just say the jury is still out. To be fair 5500 rpm, Improper belt tension, bearing on alternator completely shot and finally improper alignment . Now that all issues are addressed we will see how it goes. By the way, found out you can use a chevy alternator on a ford just need a 7/16 drill bit to widen the bottom hole and a spacer found a 100 amp single wire chrome for $120 at my local speed shop. They wanted $ 240 for the crome ford one.
Just because you can doesn't mean you should. I MUCH prefer a Ford 3G over the common GM style 1-wire alternators. At least part of the reason can be found in this Web page: Catalog
Brian
