Old 02-09-2021, 05:55 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Default Bob - which electric fuel pumps does ERA use
Bob,
I am having a 496 built that will have 600hp. My engine builder says I will need a fuel pump that flows about 140 gph. That means an electric pump.
When ERA builds a turn key, which pump do you like to use?
The Aeromotive Phantom in tank units look nice. T style pumps are notoriously loud. In tank would keep noise down.
The Aeromotive has 13 amp draw. Would that work with your 15 amp circuit or should I run a relay from one of the fuses and use the 15 amp circuit to switch it?
Which fuse would you run from?
Just planning and collecting parts for 838.
John
