Old 02-10-2021, 05:39 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
I am down to two electric pumps.
The easiest to install is the Aeromotive SS 11203. It is 140gph and only draws 5 amps. So the standard ERA wiring and plumbing should work.
The Aeormotive Phantom is a basket type that goes in the tank and supports 750hp (flow rate not given). It would require more effort to wire it as it draws 13 amps and would need a relay wired in.
Not a big cost difference and both can be ran without a return line.
I will stew on this and decide later. The noise level on the first one is the hold back.
John
