Old 02-11-2021, 05:34 PM
bcrumpley's Avatar
bcrumpley bcrumpley is offline
Cobra Make, Engine: ERA #828
Are you saying it won't clear the trunk floor without some modification to the aluminum?
There's about 1/4" between the tank and trunk floor, the exposed part of the pump is close to 3/4", so they have to modify the front of the trunk floor.
Did you wire it like Bob indicated above?
I'm using the ERA supplied wiring with no issue.
Did you mount it on the Left side of the tank just past the trap door?
It's mounted at the very front in the center.
What is your engine setup? Are you happy with the unit?
445 FE with BBM heads, spec'ed by Brent, probably making a little north of 500 hp. Love it, but would be happier if it didn't leak oil. I blame the dumbass who assembled it.
Bobby
