Old 03-10-2021, 01:06 PM
patrickt patrickt is offline
Originally Posted by sgianino View Post
Hi Patrick,
I went to put in the new PL700, even with the trim ring fully tight the bulbs are loose...would you use a rubber shim behind the Lucas tabs or shim the trim ring against the glass of the beam?
Or are there different trim ring sizes? would that be a better bet, maybe one that is not as deep that came with the car...Wasnt sure if all trim rings where the same,
Thanks
It should fit without having to do any shims. I bet that's not the right trim ring. If you can't get one that fits perfectly, I would opt for which ever trimming holds the bulb the most secure. Headlights get a lot of jiggling, even if you don't think they do. If they're not securely fastened, or securely shimmed and fastened, they're going to end up pointing over in to a corn field or into oncoming traffic.
