Old 12-01-2021, 06:51 AM
spdbrake spdbrake is offline
Originally Posted by sea2jet View Post
I’m looking for a set of side pipes for a 428 powered ERA. I would like SS, but if that’s not an option, I could do regular steel. I tried GasNPipes but they can’t get the SS tubing for the primaries. I’ve been waiting over a year. Thanks…
If you can get Georgie @ Gas-N to tell you the center-line radii he needs for the inboard and outboard tubing to correctly nest them, these folks can make the tubing bends he needs.https://russellstubeforming.com/rota...ding-services/
IF he doesn't know the radii used (hard to believe)then he can at least tell you the gap between the pipes needed for the merge collector then the radius of each pipe can be calculated.
