Old 12-25-2021, 08:32 AM
fastpace fastpace is offline
Cobra Make, Engine: CSX2410
Originally Posted by 767Jockey View Post
I've been told that I can eliminate the red light and just put a 560 ohm resisitor in the line that goes to the ignition switch. If that's true and that'll work, that's fine with me. I have a functioning voltmeter and no use at all for the red light as a warning. Will the 560 ohm resistor in the line to the ignition switch without the red light being hooked up work as a way to excite the alternator into action?
Yes you should follow the wiring information you posted under "Cars with 5 gauge cluster" then. So the Lt Grn/Reg wire off the "I" ignition terminal should go through a 560 ohm resistor to a switched power source that is powered at both the start and run positions of the ignition.
