  #29 (permalink)
Old 01-25-2022, 09:22 AM
brad-cam brad-cam is offline
Cobra Make, Engine: FF, Ford 347
Thanks, I might go that route. I need the 45deg type. I also don't have the coolant bypass connected (port on thermo housing is plugged), just the pin valve in the thermostat. I plan to add the bypass hose to the water pump port (as OEM). That might be unrelated to the side-to-side temp imbalance I am seeing, but I think it should be there.
