Old 10-09-2022, 12:18 PM
mjhcobra's Avatar
mjhcobra mjhcobra is offline
Cobra Make, Engine: Everett Morrison, 428
I have a similar frame and I used a sway bar from a 1980 pinto wagon, which I believe was 15/16" diameter. This larger bar required larger bushings (Energy Suspension 9.5109G) and sway bar links. I could not find the part number for the link kit, but should be that for the 1980 pinto wagon. This sway bar uses the holes in the EM frame brackets.
I have since gone to a narrowed by 5/8" each side, adjustable coil over front end to correct tire issues with the fenders. I no longer run the front sway bar and have had no issues.
