Old 04-05-2023, 11:33 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by Unique427 View Post
Fel Pro makes a steel core lined intake gasket.
The steel lining is sandwiched inside the usual gasket material.
Designed to stay in place and not deform or tear due
to high vacuum, possible crankcase pressure, etc.
Can't attest to it personally, but guys I know who blowout
intake gaskets annually have used these with good success.
Good luck.
Link:
https://www.felpro.com/parts/perform...d-gaskets.html
The gasket on the supercharger on my Ford GT was of similar construction. Indeed, I feel that under boost this gasket would have been a weak point but it showed no deformation and was easy to remove and replace and reuse when I had to R&R the blower. If a gasket of this type is available I'd recommend it.
Tony
CSX4005LA
