Old 05-24-2023, 08:10 AM
Maxjeep Maxjeep is offline
Cobra Make, Engine: Shelby CSX48xx from South Africa
Originally Posted by Dominik View Post
Should you not have the bigger holes (1.5" diameter) in the outer brackets, to receive the cup washer?
The cups go in the inside brackets. I’m waiting for new cups. I turned down a couple of fender washers and drilled holes in them so I have a solid fit. I sandwiched them between 2 larger washers. I think it’s more accurate than using the cups. This made it easier to get the right distance between the brackets also.
