Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
Like Tree10Likes
  #41 (permalink)
Old 05-24-2023, 06:40 AM
Dominik's Avatar
Note, CSX 4750 to CSX 4760 were meant to be built in South Africa. Perhaps two up or down. Six of them actually left the country, sort of finished. And then onwards from some number similar to yours?
If I don't respond anymore, that's because I can't log in
  #42 (permalink)
Old 05-24-2023, 06:49 AM
Dominik's Avatar
Seems I cannot attach (chassis) pics. I also see that you are from Vegas.
Weren't, after the SA factory closed down, them CSX 4000 cars built in Mexico and a prison in Vegas?
What I am saying is, there should be know how and possible parts nearby.
  #43 (permalink)
Old 05-24-2023, 06:52 AM
Dominik's Avatar
Originally Posted by Maxjeep View Post
I’m making some progress. I’m trying to align my 3 new brackets with my good one. I have the right distances between 3 of the 4 but I have too much pressure on the last one. The 2 inner brackets are perfect with the other side. I’m thinking that I need to remove 1/8” on both outer brackets. The degree and angle of the inner brackets are a perfect match.
Should you not have the bigger holes (1.5" diameter) in the outer brackets, to receive the cup washer?
  #44 (permalink)
Old 05-24-2023, 07:10 AM
Cobra Make, Engine: Shelby CSX48xx from South Africa
The cups go in the inside brackets. I’m waiting for new cups. I turned down a couple of fender washers and drilled holes in them so I have a solid fit. I sandwiched them between 2 larger washers. I think it’s more accurate than using the cups. This made it easier to get the right distance between the brackets also.
Dominik likes this.
  #45 (permalink)
Old 05-24-2023, 07:13 AM
I confirmed with Tony at Shelby that my car was built in South Africa. Shelby doesn’t sell parts for their cars anymore and they have turned it over to Superformance… much to my surprise.
  #46 (permalink)
Old 05-31-2023, 11:02 PM
Dominik's Avatar
Well, Superformance builds them here in SA. But it is a surprise that nobody in the US can help you with parts. Some cars and their bodies had been made in the US at HST (are they in Vegas?) before Superformance took over in SA.
I am surprised that there is no mold in the US left to make body parts. Granted, they scrap them after they are worn out. Or shipped back to SA.
What else do you need? Did you check with the scratch builders?
I just checked, yes my bad. Cup washers on inside at the lower, outside at upper. I built without them and sleeved to within 1/10 mm.
