Old 06-25-2023, 04:30 PM
eschaider's Avatar
Originally Posted by Austria_Cobra View Post
A Cat does chemical reaktions, HC is the most smelling part I know sofar and a Cat should split that.
I was told that the standard smell on exhaust gas will be significant reduced , as the cat is on working temperatur.
Unburned gasoline will not be effected.
I think you may have answered your own question Austria Cobra!
As long as you have made these determinations, I would throw caution to the wind and just go for it — if I were you. Based on your knowledge, if you put two or more of those on each bank and then use the proper fuel fragrances, that Patrick has already pointed you at, you should be good to go!
Personally, I think the "Reefer Madness" would be an excellent choice, with potential fringe benefits.
