Old 10-10-2023, 09:10 AM
eschaider's Avatar
The rotor you want to use and a bearing catalog are going to be your friends in this effort.
Most bearings are offered in multiple OD sizes and widths for any given ID. You should be able to identify a suitable replacement-bearing candidate with a little search time between the covers of the catalog.
In a worst-case scenario, you would need to produce an insert to press into the rotor to match up the bearing you want to use to the rotor you have. The other possibility, assuming there is adequate material in the rotor (there may not be), would be to bore the bearing register in the rotor to the correct diameter to fit a bearing candidate you have identified and want to use.
This boring idea is fraught with challenge. If you leave too little supporting wall for the bearing, the rotor could fail while you are driving, presenting you with an exciting afternoon outing. Additionally, let's not forget the possibility you will need to redrill the rotor for a different bolt pattern. I don't know if this is the case. However, for example, the GM (I think) front rotors on my SPF needed to be redrilled to match my knockoff wheels' drive pin register.
You will have an interesting journey here. Keep us up to date on what you discover.
