Old 10-16-2023, 04:30 AM
joyridin''s Avatar
joyridin' joyridin' is offline
The ones made by Wilwood are either billet aircraft aluminum, or a steel forging. A standard off-the-shelf rotor is cast iron....probably made in China.
It is one thing when it is integral, but you are putting together pieces, so it is nowhere near as strong. I would be a bit concerned if I was cranking around a corner with that set-up.
