Old 11-18-2023, 06:19 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Bob K View Post
I have these guards around my pipes and they only get to about 98 degrees. The header reaches 280 plus and the rest of the pipe hits around 220-240.
I can lay my hand or calf on the guard without a burn. Granted I just got the car and only had it out a couple of times, but each time I checked with a heat gun and it was always under 100 degrees.
https://vintage-motorsports.com/piwi...9/category/853
Is that degrees Fahrenheit? If so that is one of the coolest running motors I’ve heard of. My headers at idle are in the 400 - 500 degree range. I have undercar exhaust but I’ve measured my mufflers at over 400 degrees after shutting off from a drive.
I have an old Corvette with chambered side exhaust and the GM aluminum guards. They fit fairly close to the pipes and get a little warm but they have a layer of fiberglass glued to the inside that’s about 1/8-3/16” thick for an insulator. I would be surprised if shields do much good without some sort of insulator or a large air space.
ERA 782 Running
