Hey Jack21 and DScott
First...Jack21...ya I let my brother hook up the lights in the back...and I think you have it right...switch out the double in the rear for the single in the front. Hope that corrects it...and the wipers...Hmmmm give me a couple of days, all be back. Jack what is a VOM meter...is it the same as an Ohms meter? Or does VOM stand for Voltes and Ohms.
DScott...The switch I have for the lights is a three positional switch...so all switch out the the top rear flasher light for the front...and then will see what happens...I wondered about the extra wire in the front...it only makes sence that the front flasher light should be a double filament and all four rear lights are red...is this a problem? Should two be amber? I left this up to Enzo at FinishLine when I order them.
Thanks Guy's you've been a GREAT HELP!!
Snake.
P.S. Don you wouldn't happen to have the latch set up for the rear deck lid, and the four rubber hood rests.....would ya?
