Old 07-30-2002, 05:28 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Sorry, I can't get a good picture with the engine compartment completed and the hood on. The brace or bracket is 1" square tubing, mitered and welded in an inverted "U" with the legs pulled out. Each leg has a flat tab welded in place and drilled to accept two 3/8's bolts, one on each side of the leg. This sits all the way down onto the front cross member uprights. We simply drilled and tapped 4 matching holes, (two on each side).
It sits in very tight, does not interfere with wiring, brake lines or steering components. Once bolted in place, I swear you could hook a "lift" to it and pick the entire nose off the ground!
It is then easy to mount all kinds of goodies to it, even with the "Supercharger in place". leaving the wheel tubs clean and all accessory's away from the headers.
Ok, here's the pictures.
Any questions?
DV...the best part is you don't even have to crawl under the car to remove the filter. Now if we can just figure out how to get to that drain plug!
