Old 08-19-2002, 12:01 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
You sounded like you were on the fence between webers and an individual runner fuel injection system.
The problems you have with ther Hilborn FI setup is inherent on a multicarb setup as well. Even with multi-feedback efi, since you are not running a factory setup, you will still have to tune by plugs, sounds, and drivability to get your baseline tune-up. The differences between carburators and fuel injection are numerous, even with true mechanical FI. Mechanical FI makes more power than carbs. A simple efi controller that mimics mechanical FI fuel delivery will make more power too.
