Thread: WOW thats BIG!!
Old 01-01-2003, 05:37 AM
750hp's Avatar
750hp 750hp is offline
John, I've edited my message as we posted near the same time... Scott OZVENOM builds some "out there" machinery that others don't have the talent / foresight / balls to build. His AWD twin turbo car will be an amazing sight when it's finished. It's in the early stages at present - the Lexus Quad Cammer is installed, along with the Nissan GTR independent rear. The car is complete and registered, currently in rear wheel drive configuration. I've seen the front diff, turbos, intercooler and plumbing - all ready to go when the time arises. Can you imagine what a 600+hp, AWD, 2200lb Cobra will accelerate like!?! The hood scoop shown is actually mine. I thought it might look a bit smaller after it was painted, but it didn't shrink one little bit!!! I'm running a 90mm throttle body over the top of my MSD distributor which necessitates the radical departure from standard specs.
Anyway - what are you doing awake at 6am on NYD??? Happy New Year!
Scott, I have a proposition for you.
You have done (or will do) the following on my car :
Chassis work
Suspension work
Steering work
Engine mounts
Transmission mounts
Fibreglass work - including the infamous Mount Kosciuszko...
Roll bar and mounts
Custom dashboard
Lift-off front
Brakes
Engine start-up and checking
Seat belts
Seat mounts
Door and boot latch assemblies
A million various fabrication jobs
Complete assembly of vehicle
Complete systems check.
In return, I offer the following:
Spell checking
Advice regarding correct construction of sentences
Punctuation advice, and
Photography tips on minimising glare and reflection....
Don't get all offended and charge me more money for your labour costs now!!!
While I'm here joking about your cheery lack of concern for correct spelling and punctuation, you're probably out in the shed turning up some trick little custom fabricated bits and pieces that'll blow me away the next time I visit. The end result is that while I can type on a computer all day about building Cobras, you're out there actually doing it....
Craig
