Old 02-05-2003, 01:48 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Hector - personally I can't see how an accusump system can be 100% effective without a check valve, certainly for pre-start pre-oiling. You need to ensure that all of the pressurised oil from the Accusump goes to the right place.
The possibility of the valve "sticking" is fairly remote if you go for an (expensive) flap valve type of large diameter. I would use no other type.
Without going to check, I seem to recall that a non return valve is shown on the Accusump instructions.
Wilf
