Old 04-19-2003, 08:02 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Default Fuel return line
I'm converting to a return fuel system..About the return line inside the tank.I remember mentions of making the end of the tube reach to the top of the tank ,running it along the tank side. Any guidance ? pros and cons.? dos and don'ts?Any trick ends ?
I have a alluminum tank 25 gal with a sump. The sump currently has three 1/2" NPT bungs,two pickups and one a drain.I plan on installing #10 AN weld in bungs. The return is yet to be planed.I want some sugestions and recamendations.It's a 24x24 x12 with sump forward.I have a 3 1/2" side neck connected to verticle fill byway of a 3 1/2" neoprene elbow. I plan on keeping the return point below the elbow.Now it looks like a large tube tigged to the inside of a #10 bung pointing upward to top of tank. I have a small vent at the gas cap. I should keep airation and expansion to a minimum,fumes are lost fuel.
Mike H
