Old 04-25-2003, 06:41 PM
KobraKarl's Avatar
KobraKarl KobraKarl is offline
Wheels,
I went through this whole dilema myself 5 months ago. I talked with some very respected FE builders and picked the brains of some very worthy guys here on the CC board.
I learned some do deal with this problem with epoxy, but that wont solve the fact that your runners are also too narrow by an 1/8 to3/16 ,and you are restricting the opening to your ports.
another problem with epoxy is, it wont raise the floor of your manifold and you will pool fuel ,you will run rich and your car will stink the place up ! It was also suggested to me that the pooling fuel could possibly grenade your whole top end ,or at least give you a fire that might be real hard to put out !
If you port match the heads (assuming you have enough extra metal) and you dont like the end performance results,(a real possibility) then you are stuck with heads that wont match a mid riser manifold.
You need one more inch of clearance for a midriser manifold,they perform better than the low riser ,they look better, and they are about 500$, ..........I bought an original on E-bay ,but you can get a real nice BLue Thunder repop for less.
Good luck, Karl
Foolish consistancy is the hobgoblin of tiny minds
