Old 06-22-2003, 08:22 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thanks Perry....That's kind of the way I'm looking at it....and you're right....I installed the 4.10s because I have a World Class T5 with a huge jump from 4th to 5th. The 4.10s work well in overdrive with a 28 inch tall rear tire, but when I went to the 17"ers with a 26" rear height I just stopped using 1st at all. 2nd gear starts are fine. It still cruises pretty well in 5th, but I need to get back to the taller tire or change back to the shorter gears. I had a 3.55 before....didn't work well with tall tires...would work great with the 17" wheels, but I don't like the looks of the 17s, regardless of how well they perform. Hoosiers for a spare set would be a fun idea!
