Old 06-26-2003, 04:14 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
What kind of rear end are you going to run? That will be the weakest link if you have IRS. I don't think you will need or want any more that 3.55's out back, unless this is a bonafide drag car (maybe even then) you won't have OD, so rear gear ought to be a bit more conservative.
