Old 07-25-2003, 07:20 AM
Roscoe's Avatar
Roscoe Roscoe is offline
My rear leaked from the vent also. Just install a hose over it and run the hose up like the vent on the fuel tank. Problem goes away.
As far as bottoming out, this seems to be a problem with A&C and the chassis thing I mentioned earlier. I believe the new chassis's are slightly different than the older ones and the control arms do not reflect this. I installed adjustable uppers in order to bring the pinion down to about 2-3 degrees. The Cobra should have a slight rake to it naturally but not real great, like an inch or so.
By the way, Tommachine is the guy I mentioned to you in a private email. He owns a machine shop.
Roscoe
Roscoe
