  #24 (permalink)
Old 08-05-2003, 07:30 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Your idle adjustement is for the idle only. That's all those screws are for, if it idles nicely, good job. The moment you touch the throttle (even a little) you are then into the accellerator pump circuit, and there you have cams and squirters to play with.
