Old 08-07-2003, 06:59 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Mine are set up like this:
My frame mounts about 4" long and appear to be made of two pieces of 1/4" X 3" X 4" flat stock welded into an inverted V with a piece of 5/8" steel tube welded on top.
My motor mounts are two pieces each side bolted to the block with 3 - 5/8" course thrd bolts about 1" long. The outside mount bolts up to a flange to the inside mount with two bolts and also to the frame mount with a 1/2" x 6" long grade 8 bolt.
I had to flip through several pages of motor mounts at the NAPA store to find the exact ones I needed. Each motor mount is identified with a picture and a part number. The guys there was very patient with me. It also helped that I stopped in at a time when they were not very busy.
Good Luck
"Let's roll"
"Be part of Something Good
