Thread: braking
Old 08-26-2003, 10:43 AM
cruzin' cruzin' is offline
I don't have a cobra yet but I want one. I do however have a tubular frame race car that has four piston calipers and manual brakes that used to pull to the right. My problem was one of the calipers was not properly centered on the rotor. I used aftermarket knuckles that are not perfect from the left to right. It causes a hard mounted caliper to only brake on one side of the rotor, . . .therefore having less braking torque on that side of the vehicle. You might want to take a look at this. A little shim fixed the issue.
Hope this helps,
Neil
