Old 08-30-2003, 07:55 PM
Ikestaa Ikestaa is offline
When you say ignition switch, do you mean the ignition post on the ignition switch? Also, I assume the neutral safety switch is open if in gear and closed only when in neutral. Either way, we don't have one wired in to our harness. I am sure this setup would work, but I remember bob having a little easier way to do it. I did a continuity test and found a half ohm between both the ign - st and bat - st terminals on the ignition switch with the starter engaged (battery was not hooked up though). Could I run two wires from the ign and bat to one post on the button and run the other post back to the st terminal?
2500 Pounds of steel, rubber, and fire. AAAHHHH!
