  #24 (permalink)
Old 09-02-2003, 11:54 AM
kingkobra kingkobra is offline
Cobra Make, Engine: Factory5, 5.0L
Did you check the ring end gap? If the ring ends touch when installed in the cylinder, the assembly will be really tight. I've heard of this causing engine seizeure.
I don't want to insult your intelligence but you should check the ring gap by installing the ring only in the cylinder (push it in with a piston to square it up to the bore).
Check your ring instructions, but there should be about 0.050" end gap.
Have fun!!
