Old 10-09-2003, 10:00 AM
decooney's Avatar
decooney decooney is offline
Default other things...
Hey Chaplin,
I know we talked about cam specs and gear ratio combos in the past a bit. I've been doing even more experimintation with tuning and believe I have come up with a way to make the car just a little more driveable at lower rpms, with the bigger cams and crusing speeds.
Send me an email on the following so we can compare.
- Your Carb type(s) and #
- Carb stock or altered some?
- Air Filter type(s)
- Jets in Primary & Secondary if you know
- Discharge Nozzle numbers used on carb
- Size of Power valves in carb
- Thermostat temp used
- Timing setting
Talk to you later.
Duane
