Thread: wheel hopp
Old 10-20-2003, 10:32 AM
decooney's Avatar
decooney decooney is offline
Default Re: Duane
Originally posted by rdorman
Also the lower a-arm inner bushing where solid and not rubber?
Thanks
Rick
- Stock bearings, stock steel shims, stock rubber separators. Never tried the solid bushings on the Unique, worked okay as-is with the rear tri-bar setup. If you don't have it now, I can tell you for certain it was the best investment I ever made to my Unique and the results were excellent; especially when on the throttle coming in to a turn and even more so coming out of a turn. Before that it felt like the Jag IRS in the Unique was sort of flopping all over the place under load and over bumps, etc.
Duane
