Thread: EFI on an FE
Old 11-28-2003, 01:24 PM
Sizzler Sizzler is offline
Originally posted by Cobra75
Sizzler,
That sounds great. What engine and induction system do you have? Is it an FE with the TWM induction?
Awhile back, one engine builder I know could never get that setup to work perfectly. It looked great but couldn't get it tuned correctly even with a visit to Electromotive.
It's an FE. Dual quad (with two sets of butterflies in each "quad") with separate plenums. I use a chamber connected to each plenum for the MAP sensor and I have the remote TPS just like you'd need with a TWM setup.. It's not 8 IR's, two sets of 4. It does have 16 injectors (2 per port, staged).
To summarize, 4 sets of butterflies (versus 8 with TWM's) all of which need to be set, adjusted and coordinated together, progressive linkage, 16 staged injectors (so not only do I have secondary throttle blades opening, I have tertiary? staged injectors coming on line as well under full throttle). I tuned it myself. It not only runs great, it passes emissions and gets great mileage too.
So, what engine builder couldn't get it tuned. This is a forum to share such information so that we can either support or avoid such builders.
Good thing I didn't hold my breath waiting for a response or for someone to name names...
