Old 12-13-2003, 10:47 PM
Keithc8 Keithc8 is offline
Default If you want more than your tipical 402 crate engine
We just finished Keith Williams 396C.I. aluminum 351W SB Ford for his Super Performance Daytona Coupe. This is a real nice engine and I appreciatte Keith having the confidence to let us build him a nice engine with nice parts. This engine is built with a Dart aluminum SBF block that is 4.100 bore and has a Scat 4340 steel crank with a 3.750 stroke, Scat H-beam rods, JE custom pistons, hydraulic roller camshaft, AFR 205 heads, stud mount rockers, Edelbrock Performer RPM intake and 10.3 to 1 compression with a 950 DaVinci carburator. This engine was run through 13/4 step into 17/8 headers. This engine really surprised me with a max tourqe of 556ft/bls torque and 585HP at 6000RPM's. The engine made 570HP between 5600 and 6500RPM's and did not fall of till about 6800RPM's. That is really neat for a dual plain intake and a hydraulic roller camshaft. Max torque was at about 4700RPM's but the engine had about 450ft/bls by 3500RPM's.
Just wanted to let everyone know there is a alternative to a 402 crate engine that only makes 500ft/bls torque and 500HP and cost about the same in a steel block and about 2200.00 more in an aluminum block. This should be fun to drive, about as fun as Gary's 640HP Cobra that I got to drive. Thanks
Keith C
