Old 12-19-2003, 11:02 AM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Charles, best bet is that you've blown a header gasket. I had the same problem a while back. Just like Blykins says, pull the header bolts, unbolt the side pipe from the frame (if yours is anything like my Unique) and take a look at the gasket (you might need a mirror depending on sight clearance).
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
