Old 12-19-2003, 07:24 AM
Cobra Make, Engine: lonestar 427-408stroked 351w roller
Default 408 stroker backfire problem
good morning
i have problem, my engine backfires out of right sidepipe
after each shift.when i accellerate hard it backfires.easy and
it doesnt.
thanks
Old 12-19-2003, 07:32 AM
Could possibly be a blown header gasket on that side....or you could be running pretty rich on that side also. Check your spark plugs and see what condition they're in. Might also wanna yank the header off on that side, and see if you can see any tinged areas.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 12-19-2003, 11:02 AM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Charles, best bet is that you've blown a header gasket. I had the same problem a while back. Just like Blykins says, pull the header bolts, unbolt the side pipe from the frame (if yours is anything like my Unique) and take a look at the gasket (you might need a mirror depending on sight clearance).
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 12-19-2003, 12:27 PM
THANKS FOR THE HELP. ILL BE PULLING THE HEADER OFF TONIGHT.
AGAIN THANKS!
