Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 12-11-2009, 09:42 AM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default 460 Pilot Bearing for Manual Trans
I wanted to know what type of pilot bearing you guys are using with the 385 series engines and the Tremec transmissions. I decided to use a roller bearing type with my TKO 600 but is anyone using the solid bronze types and why ?
Thanks
"...some assembly required, ages 8 and up...... well that took longer than expected......
Old 12-11-2009, 09:58 AM
FWB's Avatar
FWB FWB is offline
does the roller type have a specific life span? how do you know when its wrecking your crank due to galling. my ignorance would make me go with the bronze....
Old 12-11-2009, 10:02 AM
kitcarbp's Avatar
The only info I have is the input shaft hardness must be sufficient to be able to use a modern needle bearing type roller bearing which I am using. The TKO input shafts are hardened and should not care either way, but I have a noise I am trying to pinpoint.
Old 12-12-2009, 04:18 AM
mdross1's Avatar
Bronze for this cat,mainly because they are self lubricating,and tolerate slight misalignment,Very slight,more, the trans will not be happy.
