Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 04-14-2010, 05:16 PM
Default SB-100 PCV to air Filter kit
I went on Monday for my inspection by the BAR and passed everything except i need to have my pcv breather routed to the air filter.
The inspector kindly printed out a picture of a kit by Ford racing but I can't find it anywhere online. Does anyone know where i can get one of these?
Old 04-14-2010, 08:06 PM
i don't know where you are in Ca but you can try Mustangs Plus in Stockton, http://www.mustangsplus.com/xcart/home.php
Terry
Old 04-15-2010, 07:19 AM
Cobra Make, Engine: SPF #1019
Huh? Which year do you choose for your "body style" for Smog purposes?
Old 04-15-2010, 07:32 AM
Ron61's Avatar
Are you talking about the PCV valve on the passenger side of the engine? If so, I just had mine routed to the place on the spacer behind the carb. I also drilled a hole in my air cleaner and attached a small tube through it so I could use a breather type cap on the drivers side but neither was required by the inspector when he checked my car.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-15-2010, 07:57 AM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
I have a picture of an original Cobra showing the piping from the filler cap to the air cleaner. After trying for the past 1/2 hour to download onto this thread, I have decided that it is impossible to download photos with Windows Vista to Club Cobra. I can e-mail you the picture if you send me an e-mail address.
Old 04-15-2010, 10:51 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Not that hard to do (I also had to put a hose from the breather to the Air Cleaner to augment the existing PCV setup). There are plenty of inexpensive lightweight breathers out there with a hose nipple for just this purpose. Then get a 90 deg (or other) plastic fitting that you can attach to the bottom of your filter housing--I think I got mine from Summit Racing. Then drill a hole in the base of the housing, attach the elbow (so that it does not interfere with throttle/choke/carb/filter function), insert one end of the hose on the fitting and the other on the nipple on the installed breather, and you are in business with a closed-loop system.
I think that I found the plastic elbow fitting at Summit Racing under air cleaner accessories.
Good luck
Bill
"If your work speaks for itself, don't interrupt"
Old 04-15-2010, 01:36 PM
There are threads on this topic.
I bought the parts to fabricate the closed system from the driver's side breather from Kragen/Oreilly for $15.
If you're close to San Diego, you can borrow my setup. Includes everything from the breather to the air cleaner.
